The macro tells me : umbraco was unable to parse a macro tag, which means that parts of this content might be corrupt.
I know, because i changed my .Net usercontrol and the macro. So I want to update it on my content page.
Unfortunately i can't edit my content page because the only think availeble there is the macro. You can't update or delete because I'am in a a mceNonEditable erea. If i could i would enter the HTML mode to remove the macro manually from the content page and re-add it.
Remove invalid macro
What do i do? Update the database manually?
Hi Damian
Hmm...can you click on the macro or mark it and then hit the "Delete" button on the keyboard?
Otherwise...is it possible for you to delete the entire node and recreate it again? (Without the macro of course).
It didn't work in FF, but trying IE8 solved the problem. The toolbar worked and we could enter the html mode.
(colleague of Damiaan)
