  • vdykcj 3 posts 20 karma points
    Mar 29, 2009 @ 14:26
    vdykcj
    Samples
    Hi All
    We are seriously looking at using Umbraco but do have some concerns. Could existing users please supply URL's to their Umbraco sites so that we can see what is actually possible with the 'friendly CMS'.
  • Comment author was deleted
    Mar 29, 2009 @ 14:37
    Mar 29, 2009 @ 14:38
    Also the old umbraco site has a showcase section (but these sites are pretty old)
    http://old.umbraco.org/frontpage/product/sites.aspx
  • David Conlisk 432 posts 1008 karma points
    Mar 29, 2009 @ 15:26
    David Conlisk
    Here are some sites that I've been involved with recently:
    http://www.beaconpurchasing.co.uk
    An upgrade of a site from a pre-existing CMS to Umbraco. Integrates with existing database systems, and provides two different types of site login area for suppliers and customers.
    http://www.singlemaltwhiskyshop.com
    A bespoke e-commerce solution including integration with SecPay and internal stock systems.
    http://www.reedinpartnership.co.uk
    Lots of reuseable components, a member login area, Google maps integration, etc.
    Hope that helps you make your decision!
    David
    Mar 29, 2009 @ 20:08
    vdykcj
    dconlisk
    It seems that any 'look & feel' can be obtained and that there is no limitations. I am seriously pressed for time and need to deliver a project within the next month.
    Is there any chance in sharing the document types, templates, Stylesheets etc for reedinpartnership?
    Mar 30, 2009 @ 10:44
    David Conlisk
    I'm afraid that won't be possible for a number of reasons, the main one being that I don't have access to those files any more. Also, they belong to the agency that employed me to do the work, so it wouldn't be ethical for me to start handing them out.
    A month could be okay to get your site going - feel free to abuse this forum and get in touch with Umbracians with questions and problems. I think you'll find you'll get a lot of help - it's a very friendly community! You can contact me directly through my website http://web-garden.co.uk if you have any questions. There's also the option of Umbraco Pro support (http://www.umbraco.org/products/umbraco-pro) - if your client will pay for it then you get access to the greatest minds in the Umbraco community who can help you with all sorts of issues, including the architecture of the site, best practices, etc. And finally there is Umbraco TV (http://www.umbraco.org/videos) - well worth the subscription fee for some excellent screencasts on a variety of development issues.
    Hope that helps - and good luck!
    David
  • Evan 344 posts 99 karma points
    Mar 30, 2009 @ 15:57
    Evan
    [quote=vdykcj]dconlisk
    Is there any chance in sharing the document types, templates, Stylesheets etc for reedinpartnership?[/quote]
    If you have the tools and the time you can get the code and piece together the template and stylesheet. I do not really want to get into the details of this, but it can easily be done :d/
    Mar 30, 2009 @ 17:12
    vdykcj
    Thanks dconlisk
  • Bijesh Tank 192 posts 420 karma points
    Apr 17, 2009 @ 13:05
    Bijesh Tank
    [quote=dconlisk]Here are some sites that I've been involved with recently:
    David[/quote]
    Hi David,
    What commerce solution did you use with Umbraco for the singlemaltwhiskyshop.com site? Did you use commerce4Umbraco or something else? I would be interested to know.
    Bij
