Hi, since I enabled 'umbracoUseDirectoryUrls' in the webconfig, all my pages have a trailing '/' in the url, like:
www.flexisle.com/home/or www.flexisle.com/home/methodology/
even to go to the Umbraco Backoffice I need the typ an url like this:
www.flexisle.com/umbraco/
Did anyonelse encounter this problem? How can I loose this trailing '/' so that my url's look like this:
www.flexisle.com/homewww.flexisle.com/home/methodologywww.flexisle.com/umbraco
Thanks for your help,
Anthony CandaeleBelgium
I found the solution:
In umbracoSettings.config there is a setting:
<addTrailingSlash>true</addTrailingSlash>
I set this to false, and then republished the website, and now the trailing '/' is gone.
Only the url to the Umbraco Backoffice still has a trailing '/' in its url.
Anthony
Hi Anthony
Is the last thing you mention a problem or just something you conclude? - It's good to see you managed to find your way around the primary issue.
Let us know if this last part is a problem for you.
Hi Jan,
The trailing '/' to go to the Umbraco Backoffice is not really a problem, I just wonder why this is the case as all my other url's now are without a trailing '/'
greetings,
I just found the configuration setting to loose the trailing slash (/) after /umbraco
You just need to add ~/Umbraco to the "umbracoReservedUrls" setting in web.config
I found the solution here: http://our.umbraco.org/wiki/install-and-setup/setting-up-umbraco-for-friendly-urls
Greetings,
url's have a trailing /
Anthony Candaele
Belgium
Anthony
Hi Anthony
Hi Jan,
greetings,
Anthony
Hi Jan,
Greetings,
Anthony
