  • James N 3 posts 23 karma points
    Apr 27, 2011 @ 22:16
    James N
    Missing posts within a multi-install of the Blog
    I have installed the latest Umbraco 4.7 with the single blog installation. I then created a new homepage, and made the blog a child-node of the homepage.  I then created two more blogs under the homepage.  The problems start with blog #2 and #3.  The posts within these do not display.  I read somewhere that someone had the same problem, that the blog-engine only displays posts for the first blog.  Does anyone have the work-around or fix for this?
    thanks everyone
    -j
    Apr 27, 2011 @ 23:41
    Hi James
    I think that there is a modified version in the works that should work with 4.7 - Don't know when it will be released though. Just a rumour.
    But don't you get any error messages? Or does the posts just not display?
    I suspect that the XSLT for rendering the output is perhaps trying to match the old XML schema instead of the new one.
    Could you perhaps post a snippet of the XSLT code that is supposed to render the posts?
  • jivan thapa 194 posts 681 karma points
    Apr 28, 2011 @ 03:16
    jivan thapa
    open XSLT that used to render the posts, use "visualize xslt" -> choose blog #2 and #3 -> Press Visualize Xslt .
    see the outputs. if you can't see any output, you need to modify XSLT.
    Apr 28, 2011 @ 16:16
    James N
    Duh!... figured it out. I was not loading the umbBlogListPosts macro into the top of the blog #2 and #3. After adding that, it all pops into place.
    So...thanks Jan and jeevan for taking a moment to make suggestions.  The Visualize XSLT helped a lot.
    regards,
    j
    Apr 28, 2011 @ 16:23
    jivan thapa
    if it solved for you. remember to mark as "solved".
    thanks.
    Apr 28, 2011 @ 16:45
    Hi James
    Good to hear you got it solved. Sometimes it's so easy to overlook something simple, which most often causes great frustration, right? :D
    Apr 28, 2011 @ 18:21
    jivan thapa
    i agree with jan.
