  • Accusoft 58 posts 109 karma points
    Apr 29, 2011 @ 16:08
    Accusoft
    URL Name, URL Alias, etc.
    I need to be able to customize the URL of my pages.  I read a few examples using fields like Umbraco URL Name and Umbraco URL Alias but none of these automatically installed.  Is this something I have to add manually and if so, how?
  • david 46 posts 81 karma points
    Apr 29, 2011 @ 16:25
    david
    Add them to the document type properties (under settings -> document types)
    Apr 29, 2011 @ 16:26
    Accusoft
    Add what to the document type properties?
    Apr 29, 2011 @ 16:34
    david
    textstring umbracoUrlName, text string umbracoUrlAlias, true/false umbracoNaviHide etc
    more info here: http://our.umbraco.org/wiki/reference/umbraco-best-practices/umbraconavihide
    Apr 29, 2011 @ 16:35
    Accusoft
    Thank you!
    Apr 29, 2011 @ 16:37
    Tom Fulton
    Hi Chris,
    You'll want to manually add these properties to the Document Type(s) you wish to use them on.  Typically you will have a "Master" Document Type that all of your document types inherit from.  This is a good place to add these properties so they will be available on all pages.
    There is a list of these "special" properties here in the wiki - (see links on right).
    The umbracoRedirect and umbracoInternalRedirect ID should be added as Content Pickers, and umbracoNaviHide as a Checkbox (true/false), the rest should be Textstrings.  You'd add the properties by editing a document type and using the Generic Properties tab.
    For an example, check out the project Master DocType Template which includes all of these fields.  You can import this by right-clicking Document Types and clicking Import.  There's also a screenshot and a blog post there which might help put it in prespective.  Also most of the Starter Kits will have these already added.
    Hope this helps,
    Tom
