  • Paul Marden 235 posts 338 karma points MVP 3x c-trib
    May 02, 2011 @ 17:26
    Paul Marden
    Insert Span inside an H2 in TinyMCE
    I want to have a headline that looks like this....
    <h2><span>blurb</span></h2>
    I can easily create a style that appears in the styles drop down menu which inserts the <h2> or the <span> with just one style.  What I can't do is get it to insert both.  Any ideas if this is possible?
    P
    May 02, 2011 @ 18:19
    Hi Paul
    Have you tried using both <h2> and a class for the span in combination? So that you first mark the text as a <h2> and afterwards marks it with the other style?
    Otherwise I'm thinking you should perhaps consider making a tinymce template for this? You can read more about it here: http://our.umbraco.org/wiki/how-tos/enabling-the-%27template%27-plugin-for-tinymce
    I don't suppose adding the span manually through the HTML view is an option?
  • Gerty Engrie 130 posts 490 karma points c-trib
    May 02, 2011 @ 23:19
    Gerty Engrie
    I have a way, but not a nice one :p if you have a style 'h2' (style on h2) and a style 'test' (class .test) in your dropdown...
    • enter some text and add a char on the end of your text, like a . or so
    • put cursor in text
    • choose 'h2'
    • select the text without the .
    • choose 'test'
    • remove the . in the end
    that should give you <h2><span class="test">your title</span></h2>
    the reason for the . is that when you select the whole text it will make : <h2 class="test">your title</h2> ....
    not an ideal way but a way.... don't know if there's a way to insert both at the same time, would be nice :)
