Hi. I am using umbraco 4.0.1 and I created macro with user control. When I insert the macro into richtext editor, it works fine. But I am unable to delete the macro in the editor. When I try to delete the macro, the border is still there. Can anyone help me about that?
Problem at delete Macro in richtext editor
Jing
I have had the same problem and apparently there is no other solution than removing it via the html-view.
