You will need to update it. I did it using xml file that had field values that determined redirect. In my case i created data data type called department eg Sales, Marketing. In xml file i had
I passed in the name of xml file and field alias to look at. Then in send email part of doc2form i used the selected value to send email. Obviously you will have redirect values instead of emails.
Rediret depending on response... is it possible.
Hi all I have a quick question.
Is there away in umbraco to measure the response to a form and redirect.
I have installed Doc2Form.
Created a quick test questionaire, and if any of the 5 questions are NO then it's to go to another page...
Pretty simple in .net so should I try to use umbraco or just make my own control.
Doogie,
Regards
Ismail
