  • dominik 711 posts 733 karma points
    May 06, 2011 @ 13:00
    dominik
    Create own class library (c#) and use methods of them in xslt
    Is there any useful tutorial which shows how I can use some methods of an own class library in xslt?
    I found some examples but i cant get it work.
    What i´ve done:
    Create a class library in visual studio (with one method). Build it and put the dll into the /bin/ folder
    My xslt is looking like this:
    <!DOCTYPE xsl:stylesheet [ <!ENTITY nbsp "&#x00A0;"> ]>
    <xsl:stylesheet
    version="1.0"
    xmlns:testFunction="urn:testFunction"
    exclude-result-prefixes="msxml umbraco.library testFunctino">
    <msxsl:script language="C#" implements-prefix="testFunction" />
    <xsl:template match="/">
          <div>
              <xsl:value-of select="Class1:convertText('test')" disable-output-escaping="yes"/>
    </xsl:template>
    </xsl:stylesheet>
    Can someone please help?
    Everytime i try to use the xsltExtensions.config file i get also an error.
    I am using Umbraco 4.7
    May 06, 2011 @ 13:23
  • Pasang Tamang 258 posts 458 karma points
    May 06, 2011 @ 13:26
    May 06, 2011 @ 13:46
    dominik
    Hi Rich,
    I just tryed it by using the following xslt but it still does not work
    xsl:stylesheet [ ]>
    <xsl:stylesheet
    version="1.0"
          <div>
    <xsl:value-of select="ps.Helpers:uploadFileSize('String filePath')" disable-output-escaping="yes"/>
          div>
    xsl:template>
    xsl:stylesheet>
    i also copied the .cs file into App_Code
    Have i to use any new namespace declarations?
    May 06, 2011 @ 13:49
    Tom Fulton
    One more small tutorial from Tim's blog if you are using 4.6+: http://www.nibble.be/?p=95
    Basically all you have to do is decorate the class with [XsltExtension] and copy the DLL to /bin/.  Then when you create XSLT files the appropriate tags will be added at the top to make it work.
    -Tom
    Rich Green
    Edit: See Tom's post if you're using >=4.6
    May 06, 2011 @ 14:04
    dominik
    ok now it works,
    just one question what is
    RestExtensionMethod and RestExtension?
    May 06, 2011 @ 14:20
    Tom Fulton
    RestExtensionMethod is for exposing your methods /base/ methods that work similar to a REST web service.  There's a little information in the wiki:  http://our.umbraco.org/wiki/reference/umbraco-base
    In the example in Tim's blog post, that would effectively create a base method that could be called by visiting:  yoursite.com/base/TestAlias/HelloWorld, and the output would be "Hello World".  They can return XML or strings and can accept parameters like /HelloWorld/param1/param2.
    -Tom
    May 06, 2011 @ 14:50
    dominik
    Ok now i have another question.
    I created a new class inside my .cs file but i am not able to select it inside umbraco. Only one class is available
    How can i use more than one class?
    May 06, 2011 @ 14:57
    dominik
    Ok i got it i have to put in the [XsltExtension] in top of each class
