  • anthony hall 222 posts 536 karma points
    Apr 13, 2009 @ 13:43
    anthony hall
    trouble adding listview to dashboard
    I am trying to add a listview to the dashboard. I get the below error message. Other controls work fine. The control works fine outside of Umbraco. I am using cassini ( don't think that matters ) . I have the control in their project with a build event publishing them to umbraco bin & usercontrol directory. If my control just includes a literal it works fine.
    Anyway, any thoughts on what might be happening here.
    Could not load control '/usercontrols/AdminFlag.ascx'.
    Error message: System.Web.HttpParseException: Unknown server tag 'asp:ListView'. ---> System.Web.HttpParseException: Unknown server tag 'asp:ListView'. ---> System.Web.HttpException: Unknown server tag 'asp:ListView'. at System.Web.UI.TagPrefixTagNameToTypeMapper.System.Web.UI.ITagNameToTypeMapper.GetControlType(String tagName, IDictionary attribs) at System.Web.UI.MainTagNameToTypeMapper.GetControlType2(String tagName, IDictionary attribs, Boolean fAllowHtmlTags) at System.Web.UI.MainTagNameToTypeMapper.GetControlType(String tagName, IDictionary attribs, Boolean fAllowHtmlTags) at System.Web.UI.RootBuilder.GetChildControlType(String tagName, IDictionary attribs) at System.Web.UI.ControlBuilder.CreateChildBuilder(String filter, String tagName, IDictionary attribs, TemplateParser parser, ControlBuilder parentBuilder, String id, Int32 line, VirtualPath virtualPath, Type& childType, Boolean defaultProperty) at System.Web.UI.TemplateParser.ProcessBeginTag(Match match, String inputText) at System.Web.UI.TemplateParser.ParseStringInternal(String text, Encoding fileEncoding) --- End of inner exception stack trace --- at System.Web.UI.TemplateParser.ProcessException(Exception ex) at System.Web.UI.TemplateParser.ParseStringInternal(String text, Encoding fileEncoding) at System.Web.UI.TemplateParser.ParseString(String text, VirtualPath virtualPath, Encoding fileEncoding) --- End of inner exception stack trace --- at System.Web.UI.TemplateParser.ParseString(String text, VirtualPath virtualPath, Encoding fileEncoding) at System.Web.UI.TemplateParser.ParseReader(StreamReader reader, VirtualPath virtualPath) at System.Web.UI.TemplateParser.ParseFile(String physicalPath, VirtualPath virtualPath) at System.Web.UI.TemplateParser.ParseInternal() at System.Web.UI.TemplateParser.Parse() at System.Web.UI.TemplateParser.Parse(ICollection referencedAssemblies, VirtualPath virtualPath) at System.Web.Compilation.BaseTemplateBuildProvider.get_CodeCompilerType() at System.Web.Compilation.BuildProvider.GetCompilerTypeFromBuildProvider(BuildProvider buildProvider) at System.Web.Compilation.BuildProvidersCompiler.ProcessBuildProviders() at System.Web.Compilation.BuildProvidersCompiler.PerformBuild() at System.Web.Compilation.BuildManager.CompileWebFile(VirtualPath virtualPath) at System.Web.Compilation.BuildManager.GetVPathBuildResultInternal(VirtualPath virtualPath, Boolean noBuild, Boolean allowCrossApp, Boolean allowBuildInPrecompile) at System.Web.Compilation.BuildManager.GetVPathBuildResultWithNoAssert(HttpContext context, VirtualPath virtualPath, Boolean noBuild, Boolean allowCrossApp, Boolean allowBuildInPrecompile) at System.Web.Compilation.BuildManager.GetVPathBuildResult(HttpContext context, VirtualPath virtualPath, Boolean noBuild, Boolean allowCrossApp, Boolean allowBuildInPrecompile) at System.Web.UI.TemplateControl.LoadControl(VirtualPath virtualPath) at System.Web.UI.TemplateControl.LoadControl(String virtualPath) at umbraco.cms.presentation.dashbo
  • Richard Soeteman 4054 posts 12927 karma points MVP 3x
    Apr 14, 2009 @ 08:47
    Richard Soeteman
    This is because the listview is supported from ASP.NET 3.5 and you need to modify the web.config of Umbraco (which is configured by default for ASP.NET 2.0) Check out the document Install guide for Umbraco on asp.net 3.5 and integrated pipeline on Codeplex how to do that.
    Hope it helps,
    Richard
