I have a site where some of the pages have content that needs to
appear in tabs. I am using jquery for the tabs but am not sure the best
way to add the content in the backend.
I want to make it easy for
users to add the content so don't want them to have to enter the div
structure required for the tabs. But as there can be a variable number
of tabs I'm not sure how to make the tab content properties of the doc
type so they can be edited.
How will the tabs on the website be generated? Are'nt they going to mirror the content structure from the backoffice so content from tab a in the backoffice goes into tab a in the website and so on?
Or is the tabs on the frontpage made dynamically somehow that does not take the backoffice structure into account?
That's what I'm not sure of. The pages are about university courses which can last 2 or 3 years. Each page has an overview about the course and a brief summary of what is covered in each of the years. To keep things nice the designer only wants 1 year's summary shown at a time so I am using jquery "tabs" to do this, basically hiding or showing a div when a link is clicked.
This is the code shows I am ultimatly trying to produce in the front end, title and content is what I want to be editable. If the course has 2 years then 2 tabs are shown, if it has 3 then 3 tabs are shown but I'd like this to be dynamic if possible. So if the client wants to add a course with 10 years, they can.
For the time being I have added 6 fields to my doc type, tab 1 title, tab 1 content, tab 2 title, tab 2 content etc and have an xslt macro that adds an li or tab_content div if the field isn't empty. But that is no use if the client wants to add a course with 4 years or 5 years.
Ok...Then I think the most flexible thing you can do in the backoffice is to add a content repository to the root of the content section so it's at the same level as your site.
So it will look something like this
Website - Textpage - Textpage - Textpage - Etc. Courses repository Folder for course X Course Course Course Folder for course Y
Course
Course
Course Course
Course
Course Etc.
Then you have a repository where you can structure the courses in folder, so it is ordered and makes sense.
Then on your document type, representing the page where the courses should be shown you can place a Multiple node picker (From the uComponents package or just use the or the lusini picker (Can't remember the package name, but the guy who made it is named lusini). In the developer section go to the datatypes and make sure the picker you have chosen to use has the start node set to the id of the "Courses repository".
When you go to your document type, representing the page with courses you can now select all the courses you want to get information from and display them in meaningful tabs.
Below is a modifed version of the XSLT file which can be used for tabs in the same way as the accordion. You can just add more tabs with the Repeater then as mentioned in the article above.
Tabs in content
I have a site where some of the pages have content that needs to appear in tabs. I am using jquery for the tabs but am not sure the best way to add the content in the backend.
I want to make it easy for users to add the content so don't want them to have to enter the div structure required for the tabs. But as there can be a variable number of tabs I'm not sure how to make the tab content properties of the doc type so they can be edited.
Can anyone advise?
Hi Suzyb
<ul class="tabs"> <li><a href="#tab1"><!--title--></a></li> <li><a href="#tab2"><!--title--></a></li> </ul> <div class="tab_container"> <div id="tab1" class="tab_content"> <!--Content--> </div> <div id="tab2" class="tab_content"> <!--Content--> </div> </div>
Hi Suzy
Website
- Textpage
- Textpage
- Textpage
- Etc.
Courses repository
Folder for course X
Course
Course
Course
Folder for course Y
Course
Course
Course
Course
Course
Course
Etc.
Does this approach make sense to you? :-)
Yes it does.
Thanks a lot Jan.
I'm glad to hear that - please don't hesitate to ask further questions if you're in doubt about anything :-)
There's an explanation of how to use an accordion layout at http://blog.pbdesk.com/2011/02/re-usable-jquery-accordion-for-umbraco.html
<xsl:variable name="propertyAlias" select="string('Tabs')" />
<xsl:template match="/">
<xsl:if test="$currentPage/tabs/items/item">
<div id="tabs">
<ul>
<xsl:for-each select="$currentPage/tabs/items/item">
<li><a href="#{position()}"><xsl:value-of select="./data [@alias = 'TabHeader']" disable-output-escaping="yes" /></a></li>
</xsl:for-each>
</ul>
<div id="{position()}">
<xsl:value-of select="./data [@alias = 'TabContent']" disable-output-escaping="yes" />
</xsl:for-each>
</div> <!-- end of tabs div-->
<![CDATA[
$(function() {
$("#tabs").tabs();
</script>
</xsl:if>
</xsl:template>
Just another way of doing it :)
Phonsie.
