  • Jonas 49 posts 21 karma points
    Apr 15, 2009 @ 13:33
    Jonas
    Lost content when removing a generic property?
    I wonder how content is stored in the db. Let's say I have a document type with a certain generic property "someproperty", with some content using that document type, and information saved in my generic property.
    What happens if I delete the generic property from my document type? Is my ""someproperty"-content lost forever from all content nodes, or can I dig for it in the db?
    Apr 15, 2009 @ 13:54
    Jonas
    I guess that the table is cmsPropertyData and the field(s) [dataNtext]/[dataNvarchar]. However I cannot find my lost data there. Did it go away with a cascading delete?
  • Douglas Robar 3570 posts 4711 karma points MVP ∞ admin c-trib
    Apr 15, 2009 @ 14:08
    Douglas Robar
    I believe it is gone forever since there is no longer a place in the docType (or the database) to save it. Otherwise, the db could get very large with data that could never be accessed.
    If you've accidentally deleted a docType property and its data then it would be time to look into restoring a database backup.
    cheers,
    doug.
    Apr 16, 2009 @ 16:20
    Jonas
    Hi, yes - backup the SQL we should. I take it as a lesson. The installation is fresh and I had no db-backups configured. (Now I have'm).
    I'm no longer sure what happend in my case, later I did find my data in cmsPropertyData must have written a bad query the first time.
    I would (some day...) like to dig deeper into how data is stored by Umbraco. Any links?
    Thanks Doug!
