Hey Warren,
thanks for pointing me out ! i didn't know it is named as "tray" icons
do i need my controls to inherent from a Control Base class in order to be admin specific ? or i need to do a security check on Page_Load event ?
In the second part of that serie you will see the code to implement a custom tree (navigation menu). In the render method the url 'http://www.google-analytics.com' is used but you can replace that with your own url.
Adding new administration section (with icon and navigation menu)
Hey Folks,
I want to add a Section on Umbraco 4 Administration panel (beside Content, Media, Users...etc)
so here is what I'm trying to do :
1- A new section, with a icon
2- Navigation menu for this section
3- and some forms or controls specific to administration of this section.
Hi Heogue,
There are a few posts on the forum just use the search, but a quick search brings up this post.
[url]http://forum.umbraco.org/yafpostst9217Adding-Custom-Tray-Icon.aspx[/url] which should help you out alot.
Warren
Hey Warren,
also how to construct the navigation menu for the newly added section ?
The links below describe in detail how you can add custom sections.
http://www.simm.dk/umbraco-corner/articles/making-custom-sections-and-trees-inside-umbraco---part-i.aspx
http://www.simm.dk/umbraco-corner/articles/making-custom-sections-and-trees-inside-umbraco---part-ii.aspx
What's really nice is that you can create package actions for generating the Sections and Tree's see the document http://umbraco.tv/assets/package%20actions.pdf for this.
Hope this point you in the right direction.
Richard
Thank you guys !
Links are broken!
