  • heoque 7 posts 22 karma points
    Apr 18, 2009 @ 17:24
    heoque
    Adding new administration section (with icon and navigation menu)
    Hey Folks,
    I want to add a Section on Umbraco 4 Administration panel (beside Content, Media, Users...etc)
    so here is what I'm trying to do :
    1- A new section, with a icon
    2- Navigation menu for this section
    3- and some forms or controls specific to administration of this section.
  • Warren Buckley 2106 posts 4836 karma points MVP 7x admin c-trib
    Apr 18, 2009 @ 19:56
    Warren Buckley
    Hi Heogue,
    There are a few posts on the forum just use the search, but a quick search brings up this post.
    [url]http://forum.umbraco.org/yafpostst9217Adding-Custom-Tray-Icon.aspx[/url] which should help you out alot.
    Warren
    Apr 18, 2009 @ 22:46
    heoque
    Hey Warren,
    thanks for pointing me out ! i didn't know it is named as "tray" icons
    do i need my controls to inherent from a Control Base class in order to be admin specific ? or i need to do a security check on Page_Load event ?
    Apr 18, 2009 @ 22:47
    heoque
    also how to construct the navigation menu for the newly added section ?
  • Richard Soeteman 4053 posts 12926 karma points MVP 2x
    Apr 19, 2009 @ 19:40
    Richard Soeteman
    The links below describe in detail how you can add custom sections.
    http://www.simm.dk/umbraco-corner/articles/making-custom-sections-and-trees-inside-umbraco---part-i.aspx
    http://www.simm.dk/umbraco-corner/articles/making-custom-sections-and-trees-inside-umbraco---part-ii.aspx
    In the second part of that serie you will see the code to implement a custom tree (navigation menu). In the render method the url 'http://www.google-analytics.com' is used but you can replace that with your own url.
    What's really nice is that you can create package actions for generating the Sections and Tree's see the document http://umbraco.tv/assets/package%20actions.pdf for this.
    Hope this point you in the right direction.
    Richard
    Apr 19, 2009 @ 19:44
    heoque
    Thank you guys !
  • Domenico Neri 10 posts 30 karma points
    Jul 13, 2011 @ 17:59
    Domenico Neri
    Links are broken!
