  • Kev 9 posts 20 karma points
    Apr 21, 2009 @ 17:27
    Kev
    Drop down tabs
    Can anyone help me. I am trying to have my tabs so that when you hover over some of them they will drop down similar to this site
    http://www.webaward.org/winnersdetail.asp?yr=all&awardlevel=best&category=Marketing
    Is there any particular code to do this? Is it done in the style sheets or the Templates.
    Kev
  • dillorscroft 198 posts 192 karma points
    Apr 21, 2009 @ 19:11
    dillorscroft
    You need an XSLT Macro to generate a series of nested unordered list items of the site structure.
    I think the sitemap XSLT sample might veyr well build that for you anyway.
    Then use CSS to style the ul + li elements.
    Have a look at this example for using CSS to build menus... http://www.cssplay.co.uk/menus/final_drop.html
    Cheers
    DC
    Apr 24, 2009 @ 11:34
    Kev
    Thanks. That worked! I just think it makes the site look great!!!
    Kev
