I've installed version 4.0.1 of Umbraco, and TinyMCE's special character handling is bothering me.
First use case
[] I type "special" characters such as "à" or even the euro symbol
[] I save the page
[] The special characters have disappeared and were not saved, as a database lookup confirms
Second use case
[] I type "special" characters such as "à" or even the euro symbol in HTML mode by using the correct HTML equivalents such as "€"
[] I save the page
[] The special characters have disappeared, as a database lookup confirms
This did not happen in Umbraco 4.0.0 (maybe beta or code build version X, don't know what I have running on my other sites).
TinyMCE special character trouble
First use case
[] I save the page
Second use case
[] I save the page
How to solve this?
Ruben
Did you set the TidyCharEncoding to UTF8 instead of RAW in umbracoSettings.config? If not, then try that. It's a known bug in 4.0.1
Wonderful. Thanks for helping me out.
Why is it that you are "newbie" but helping "fanatics" like me? ;)
Because that only depends on how many items you got on the forum. And I must admit I haven't been all that active in the community up till now
You should, thanks again for the quick response!
Comment author was deleted
I also have this problem and followed the instructions but with no result. Here is my situation:
My database settings
Variable_nameValue
character_set_clientutf8
character_set_connectionutf8
character_set_databaseutf8
character_set_filesystembinary
character_set_resultsutf8
character_set_serverlatin1
character_set_systemutf8
character_sets_dirC:\\Program Files\\MySQL\\MySQL Server 5.1\\share\\charsets\\
my config setting
<TidyCharEncoding>UTF8</TidyCharEncoding>
My umbraco version
umbraco v 4.5.2 (Assembly version: 1.0.3891.20719)
Database connection
