  • praveity 100 posts 125 karma points
    May 17, 2011 @ 08:26
    praveity
    Save and publish gives DBCC CHECKDB error message
    Hi to all,
    Recently I have received this error while performing save or save and publish in Umbraco backend. I also run the query on my sql mgmt which shows the error at cmsPreviewXml table but I couldn't figure out the solution.
    Please help me through.
    Stack trace message is as follows:
    Possible index corruption detected. Run DBCC CHECKDB.
    Exception Details: System.Data.SqlClient.SqlException: Possible index corruption detected. Run DBCC CHECKDB.
    Source Error:
    Stack Trace:
    [SqlException (0x80131904): Possible index corruption detected. Run DBCC CHECKDB.]
       System.Data.SqlClient.SqlConnection.OnError(SqlException exception, Boolean breakConnection) +2030802
       System.Data.SqlClient.SqlInternalConnection.OnError(SqlException exception, Boolean breakConnection) +5009584
       System.Data.SqlClient.TdsParser.ThrowExceptionAndWarning() +234
       System.Data.SqlClient.TdsParser.Run(RunBehavior runBehavior, SqlCommand cmdHandler, SqlDataReader dataStream, BulkCopySimpleResultSet bulkCopyHandler, TdsParserStateObject stateObj) +2275
       System.Data.SqlClient.SqlDataReader.ConsumeMetaData() +33
       System.Data.SqlClient.SqlDataReader.get_MetaData() +86
       System.Data.SqlClient.SqlCommand.FinishExecuteReader(SqlDataReader ds, RunBehavior runBehavior, String resetOptionsString) +311
       System.Data.SqlClient.SqlCommand.RunExecuteReaderTds(CommandBehavior cmdBehavior, RunBehavior runBehavior, Boolean returnStream, Boolean async) +987
       System.Data.SqlClient.SqlCommand.RunExecuteReader(CommandBehavior cmdBehavior, RunBehavior runBehavior, Boolean returnStream, String method, DbAsyncResult result) +162
       System.Data.SqlClient.SqlCommand.RunExecuteReader(CommandBehavior cmdBehavior, RunBehavior runBehavior, Boolean returnStream, String method) +32
       System.Data.SqlClient.SqlCommand.ExecuteScalar() +139
       Microsoft.ApplicationBlocks.Data.SqlHelper.ExecuteScalar(SqlConnection connection, CommandType commandType, String commandText, SqlParameter[] commandParameters) +56
       Microsoft.ApplicationBlocks.Data.SqlHelper.ExecuteScalar(String connectionString, CommandType commandType, String commandText, SqlParameter[] commandParameters) +83
       umbraco.DataLayer.SqlHelpers.SqlServer.SqlServerHelper.ExecuteScalar(String commandText, SqlParameter[] parameters) +21
       umbraco.DataLayer.SqlHelper`1.ExecuteScalar(String commandText, IParameter[] parameters) +160
    [SqlHelperException: Umbraco Exception (DataLayer): SQL helper exception in ExecuteScalar]
       umbraco.DataLayer.SqlHelper`1.ExecuteScalar(String commandText, IParameter[] parameters) +221
       umbraco.cms.businesslogic.CMSNode.PreviewExists(Guid versionId) +189
       umbraco.cms.businesslogic.CMSNode.SavePreviewXml(XmlNode x, Guid versionId) +49
       umbraco.cms.businesslogic.web.Document.SaveXmlPreview(XmlDocument xd) +67
       umbraco.cms.businesslogic.web.Document.Save() +168
       umbraco.cms.presentation.editContent.Save(Object sender, EventArgs e) +1931
       System.EventHandler.Invoke(Object sender, EventArgs e) +0
       umbraco.controls.ContentControl.saveClick(Object Sender, ImageClickEventArgs e) +278
       umbraco.controls.ContentControl.savePublish(Object Sender, ImageClickEventArgs e) +20
       System.Web.UI.WebControls.ImageButton.OnClick(ImageClickEventArgs e) +115
       System.Web.UI.WebControls.ImageButton.RaisePostBackEvent(String eventArgument) +120
       System.Web.UI.WebControls.ImageButton.System.Web.UI.IPostBackEventHandler.RaisePostBackEvent(String eventArgument) +10
       System.Web.UI.Page.RaisePostBackEvent(IPostBackEventHandler sourceControl, String eventArgument) +13
       System.Web.UI.Page.RaisePostBackEvent(NameValueCollection postData) +36
       System.Web.UI.Page.ProcessRequestMain(Boolean includeStagesBeforeAsyncPoint, Boolean includeStagesAfterAsyncPoint) +5563
    Version Information: Microsoft .NET Framework Version:4.0.30319; ASP.NET Version:4.0.30319.1
