  • Nate 143 posts 184 karma points
    May 17, 2011 @ 18:03
    Nate
    Is it possible to call pagemethods in umbraco from jquery?
    I'm trying to get data out of umbraco with jquery. I wanted to use a pagemethod on a user control in a template.
    Is this possible? If not, is there a better recommended way get data from umbraco to jquery ajax?
    -Nate
  • Robert Foster 459 posts 1820 karma points MVP 4x admin c-trib
    May 17, 2011 @ 18:35
    Robert Foster
    Hi Nate,
    Probably best way to get exactly what you need is to create a REST library (Blog4Umbraco does this to create comments using ajax) or a JSON-based web service and use jquery ajax to call that...  If you want to create a JSON-based Web Service, take a look at the JayRock JSON library for dotNet... specifically the JSON-RPC library.
