I press insertLink and insertImage buttons when I edit content in RTE in whatever conents uses RTE
the error message is following here:
No node exists with id '-21' Description: An unhandled exception occurred during the execution of the current web request. Please review the stack trace for more information about the error and where it originated in the code.
Exception Details: System.ArgumentException: System.ArgumentException: No node exists with id '-21'
Source Error:
-------------------------------------------------------------------------------- Version Information: Microsoft .NET Framework Version:4.0.30319; ASP.NET Version:4.0.30319.1
and in umbraLog message is:
At /nweb/umbraco/plugins/tinymce3/insertImage.aspx (Referred by: http://domain/nweb/umbraco/editContent.aspx?id=6746): System.ArgumentException: No node exists with id '-21' At umbraco.cms.businesslogic.CMSNode.setupNode() At umbraco.cms.businesslogic.CMSNode..ctor(Int32 Id) At umbraco.cms.presentation.Trees.MediaRecycleBin.CreateRootNode(XmlTreeNode& rootNode) At umbraco.cms.presentation.Trees.BaseTree.CreateRootNode() At umbraco.cms.presentation.Trees.BaseTree.Initialize() At umbraco.cms.presentation.Trees.BaseTree.SetTreeParameters(ITreeService treeParams) At umbraco.controls.Tree.TreeControl.Initialize() At umbraco.controls.Tree.TreeControl.OnPreRender(EventArgs e) At System.Web.UI.Control.PreRenderRecursiveInternal() At System.Web.UI.Control.PreRenderRecursiveInternal() At System.Web.UI.Control.PreRenderRecursiveInternal() At System.Web.UI.Control.PreRenderRecursiveInternal() At System.Web.UI.Control.PreRenderRecursiveInternal() At System.Web.UI.Control.PreRenderRecursiveInternal() At System.Web.UI.Page.ProcessRequestMain(Boolean includeStagesBeforeAsyncPoint, Boolean includeStagesAfterAsyncPoint)
At /nweb/umbraco/plugins/tinymce3/insertLink.aspx (Referred by: http://domain/nweb/umbraco/editContent.aspx?id=6746): System.ArgumentException: No node exists with id '-21' At umbraco.cms.businesslogic.CMSNode.setupNode() At umbraco.cms.businesslogic.CMSNode..ctor(Int32 Id) At umbraco.cms.presentation.Trees.MediaRecycleBin.CreateRootNode(XmlTreeNode& rootNode) At umbraco.cms.presentation.Trees.BaseTree.CreateRootNode() At umbraco.cms.presentation.Trees.BaseTree.Initialize() At umbraco.cms.presentation.Trees.BaseTree.SetTreeParameters(ITreeService treeParams) At umbraco.controls.Tree.TreeControl.Initialize() At umbraco.controls.Tree.TreeControl.OnPreRender(EventArgs e) At System.Web.UI.Control.PreRenderRecursiveInternal() At System.Web.UI.Control.PreRenderRecursiveInternal() At System.Web.UI.Control.PreRenderRecursiveInternal() At System.Web.UI.Control.PreRenderRecursiveInternal() At System.Web.UI.Control.PreRenderRecursiveInternal() At System.Web.UI.Control.PreRenderRecursiveInternal() At System.Web.UI.Page.ProcessRequestMain(Boolean includeStagesBeforeAsyncPoint, Boolean includeStagesAfterAsyncPoint)
Ok, in case this helps anyone else running into the same issue on MySQL, In MySql there is no lock against inserting into an auto-increment primary key so the SET IDENTITY_INSERT can be dropped from the statement. Here's a statement that worked for me using MySQL:
Error: No node exists with id '-21'
Hi,all
what's the problem :(
Regards,
Bambe. :)
okay I found the way to fix...
http://our.umbraco.org/forum/using/ui-questions/20431-the-Media-Tree-gone-away
the node -21 is Media section's Recycle Bin
it has been deleted from unknown way
so I recovered them and fixed :)
For info, running this fixed the problem for me
SET IDENTITY_INSERT [umbracoNode] ON
INSERT [umbracoNode]([id] ,[trashed] ,[parentID] ,[nodeUser] ,[level] ,[path] ,[sortOrder] ,[uniqueID] ,[text] ,[nodeObjectType] ,[createDate])VALUES (-21, 0,-1,0,0,'-1,21',0,'BF7C7CBC-952F-4518-97A2-69E9C7B33842','Recycle Bin','CF3D8E34-1C1C-41E9-AE56-878B57B32113',getDate()) SET IDENTITY_INSERT [umbracoNode] OFFRich
Thanks Rich, your insert statement worked for me too.
Wow, old post, good to know it still helps!
Hi Rich, just stumbled upon this issue in a 4.11.8 site, however, the site is running MySQL rather than MSSQL.
Would there be any alterations to the SQL command for MySQL as I'm getting an "Unknown system variable 'IDENTITY_INSERT'" error?
Mike
