If you look in Settings > Stylesheets > Editor, you should be able to add new styles. These will then appear in the dropdown box. Remember when putting the css into the style box dont wrap them in curly brackets. (These get added automatically)
Hi z
I think adding styles must be done in some specific way, because I have created a css file and placed it under stylesheets.
I used the styles on the pages where I write the html myself. but I don't have any styles in the dropdown in my editor
Yes the styles to be used in the rich text editor must be created under the settings -> stylesheets - Create a stylesheet for rich text purposes only. You could for instance call it "Rich Text Styles". When you have done that you can create styles for headers by right-clicking your "Rich Text Styles" stylesheet and add a style called "Header" and write h1 in the alias field.
Here you can define the looks for the h1 element.
When you are done go to developer -> datatypes -> rich text editor and make sure that "Rich Text Styles" is checked.
Styles in editor
How can I add/control the styles shown in the built-in editor. I suppose it's done in a stylesheet but how is that 'put' into the editor?
Paul S
You can get a lot of info from the following post.
http://forum.umbraco.org/yafpostst4730Customised-TinyMCE-Editor-to-Allow-Heading-Tags-to-be-applied.aspx
Look for the 6 th post of 22. april 2008 16:31:06 by drobar and follow it from there.
Hope it helps you getting started.
/Finn
Hi z
Paul S
Hi Pas
I hope you can use this description.
Thanks all guys
I got it all figured out now
Finn - the 'z' was a typo - I didn't see it until the response was posted
- it should have been
Hi Finn
Thanks Paul S
