  • cato 11 posts 21 karma points
    May 04, 2009 @ 00:55
    cato
    Data type broken if not on first tab
    I am in the process of writing a custom data type where you can pick a point on a google map and umbraco will store the co-ordinates of the point.
    I have it working correctly, but only if it is on the first tab of a data type.
    I remember a similar bug with TinyMCE was fixed awhile ago.
    Any Ideas?
  • Richard Soeteman 4053 posts 12926 karma points MVP 2x
    May 04, 2009 @ 08:58
    Richard Soeteman
    Darren wrote this datatype a few months back, did you check that package? You can download it here . A screencast can be found here.
    Hope it helps you,
    Richard
    May 04, 2009 @ 23:26
    cato
    Thanks, Ill have to check it out.
    Would still be keen to find out what solution to my problem is.
    cheers
  • Bex 444 posts 555 karma points
    Jul 07, 2011 @ 11:37
    Bex
    Did you ever find a solution to this as I am trying to do the same thing and Darren's datatype doesn't work for what I want.
