  • Kyle Skrinak 272 posts 327 karma points
    May 20, 2011 @ 18:51
    Kyle Skrinak
    4.6.1 -> 4.7 upgrade breaks xslts
    My xslts have falled and can't get up!
    I did a 4.6.1 -> 4.7 upgrade by doing the following
    • Copy the contents of /bin, /umbraco and /umbraco_client from the 4.7 u folder to my existing umbraco folder (I guess that's a patch upgrade?) Note that this kept any files there that were not overwritten by the 4.7 folders
    • updated the web.config as recommended by the 4.7 upgrade instructions
    • Deleted files as advised (Iron Python/MS Scripting stuff)
    and I get the following error (but on all xslt files)
    Error parsing XSLT file: \xslt\RunwayDropdownNavigation.xslt
    I am seeing this error in the debug trace:
    System.IO.FileNotFoundException: Could not load file or assembly 'Microsoft.Scripting, Version=1.0.0.0, Culture=neutral, PublicKeyToken=31bf3856ad364e35' or one of its dependencies. The system cannot find the file specified.
    The only error VS reports is the "Error 11 Could not load type 'umbraco.presentation.install.steps.boost'. C:\Users\Administrator\Documents\MyWebSites\extra-fancy-4-7\install\steps\boost.ascx"
    Where to start?
    May 20, 2011 @ 18:58
    Kyle Skrinak
    Yes, "falled" should be "fallen" only my attempts to correct this via "edit" render this error here: Error parsing XSLT file: \xslt\forum-commentsList.xslt; ironically enough.
  • Lesley 284 posts 143 karma points
    May 21, 2011 @ 00:27
    Lesley
    Hi Kyle,
    I recently did the same upgrade path and had the same error. I found there was another DLL that needed to be deleted: Microsoft.Dynamic.dll
    (See http://our.umbraco.org/forum/getting-started/installing-umbraco/13014-MicrosoftScriptingExtensionAttribute-missing)
    Any help? If still no good, I'd suggest doing a side-by-side comparison of the files in your bin folder and those in the 4.7 release.
    May 21, 2011 @ 13:16
    Kyle Skrinak
    Lesley; I removed Microsoft.Dynamic.dll but I still have unrendered xslt macros. Following along, here's my /bin differences:
    files in /bin for 4.6.1 has that 4.7 doesn't have:
    IronPython.dll
    IronPython.Modules.dll
    IronRuby.dll
    IronRuby.Libraries.dll
    IronRuby.Libraries.Yaml.dll
    Microsoft.Scripting.dll
    What 4.7 has that 4.6.1 doesn't have:
    System.Web.Helpers.dll
    System.Web.WebPages.Deployment.dll
    System.Web.WebPages.dll
    System.Web.WebPages.Razor.dll
    Microsoft.Web.Helpers.dll
    Microsoft.Web.Infrastructure.dll
    May 21, 2011 @ 18:55
    Lesley
    Kyle,
    It looks like you don't have any custom DLLs there, so how about you delete (after backing up) your /bin folder as it stands, and then put the /bin from the 4.7 download in its place? Then you can be sure the whole folder is 4.7 -ready.
    May 21, 2011 @ 19:22
    Kyle Skrinak
    I tried that once already, but it didn't work (also knowing it would break something else)
    For clarity's sake, here's what's in my 4.7 folder that's not in the 4.7 distro (i.e., custom binaries)
    CultivContactForm.dll
    Examine.xml
    InfoCaster.Umbraco._301UrlTracker.dll
    Microsoft.Scripting.Debugging.dll
    Nibble.Umb.ZipUpload.dll
    Our.Umbraco.Tree.Config.dll
    Our.Umbraco.uDbCompare.dll
    PackageActionsContrib.dll
    RazorEngine.Core.dll
    RazorEngine.Templates.dll
    Recaptcha.dll
    Runway.Blog.dll
    TheOutfield.UmbExt.UnVersion.dll
    umbraco.MacroEngines.Legacy.dll
    UmbracoExamine.xml
    May 21, 2011 @ 19:37
    Lesley
    Oh - the upgrade instructions say to delete RazorEngine too?!
    If it's not that, then I'm running out of ideas I'm afraid :-s
    May 23, 2011 @ 00:04
    Kyle Skrinak
    Yep, removed (again; as I've restored/recopied) the RazorEngine.Core.dll and RazorEngine.Templates.dll files. Same issue, unrendered xslts.
    May 23, 2011 @ 00:41
    Tom Fulton
    2
    Hi Kyle,
    I believe you should remove Microsoft.Scripting.Debugging.dll and umbraco.MacroEngines.Legacy.dll
  • Jeroen Breuer 4909 posts 12266 karma points MVP 6x admin c-trib
    May 23, 2011 @ 07:46
    May 23, 2011 @ 14:15
    Kyle Skrinak
    Well, Tom gets the credit but it really was everyone's help; (especially Lesley) xslts are now rendering as they ought.
    Much thanks!
