  • Steven Newstead 62 posts 103 karma points
    May 23, 2011 @ 13:34
    Steven Newstead
    Link picker in richtext editor throws error when clicking on folder
    Hi all,
    Hopefully just a quick question, I am trying to see if there is a known workaround for the following:
    In the media folder I have folders and files:
    Folder A
    --->File A
    Folder B
    --->File B
    If you are in a rich text editor and try and insert an link to a media item (using the 'Insert / Edit Link') button and click on "Folder A" or "Folder B" then a 404 error occurs. If you click on the expand icon then this works as expected, however I was hoping there was some kind of work around to stop this happening?
    May 23, 2011 @ 20:37
    Hi Steven
    What version of Umbraco do you experience this on?
    It's not possible to link to a folder in the media section from the Rich text editor but you should be able to click on them without this error happening though...
    May 24, 2011 @ 09:52
    Steven Newstead
    Hi Jan,
    Thanks for the reply, I've tried this on the site we're developing and a clean install running one of the starter packs, they are both on 4.7. Hopefully it should be easy to replicate, I'd have thought that clicking on a folder would expand the folder or behave in the same way as the "Insert image" link
    Steve
  • Barry Fogarty 493 posts 1129 karma points
    Oct 05, 2011 @ 23:36
    Barry Fogarty
    Any resolution?  I am also experiencing this issue on 4.7
  • andrew shearer 513 posts 663 karma points
    Feb 15, 2012 @ 01:49
    andrew shearer
    this is an issue on 4.7.1.1 also
