  • Samuel Hamer 44 posts 66 karma points
    May 23, 2011 @ 15:51
    Samuel Hamer
    Not able to delete a document
    I am trying to delete an old section but it wont let me, it is throwing this error;
    Error handling action No Document exists with Version '1bd83169-adb4-4b82-9e52-c7e841acf270'
    Accessing it at all in the admin site comes up with an internal error now also.
    May 23, 2011 @ 20:35
    Hi Samuel
    What steps did you take to delete the section? Did you just right click the section tree inside the Umbraco content section? Or did you touch the database?
    May 25, 2011 @ 10:36
    Samuel Hamer
    So far I have just been deleting it normally, I am not that familiar with Umbraco's workings when it comes to databases so wouldnt try tinkering unless I really needed to
    May 25, 2011 @ 10:37
    Samuel Hamer
    Normally = right clicking in the content tree
  • Kerry Lindsay 5 posts 25 karma points
    May 26, 2011 @ 17:26
    Kerry Lindsay
    The only way I found to get around this issue was to manually add the missing document back into the database which then allowed me to delete the node.
  • Sean Holmesby 61 posts 82 karma points
    May 27, 2011 @ 01:48
    Sean Holmesby
    Does any other node reference the node you're trying to delete? I read somewhere that Umbraco won't let you delete the node if something else is pointing to it.
    May 27, 2011 @ 10:15
    Samuel Hamer
    Thanks for the fix Kerry
