I just reordered my Content tree for a website. I moved the Nieuws folder. It was previously under the Home node, and I moved it a level up, and now it is under the Site node:
But now I notice that the Front News xslt macro is working correctly anymore since the NewsArea document type is not located anymore under the Home document type:
<xsl:for-each select="$currentPage/NewsArea/NewsArticle [@isDoc and string(umbracoNaviHide) != '1']">
Does anybody know how I can adapt this for-each loop so that the NewsArea document type can be accessed from the Home page?
yet another xslt navigation problem
Thanks for your help,
Anthony Candaele
Belgium
Hi Anthony,
You can do a couple of different things:
If you're only using it from the Home node - do this:
Otherwise, if you'd like a more generic version, this will work on any page in the "Site" website:
/Chriztian
Hi Chriztian,
Thanks a lot. Your solution works. As I just need to read out the news items on the home page, I used your first solution.
Anthony
