Hi All,
my code is...
<?xml version="1.0" encoding="UTF-8"?><!DOCTYPE xsl:stylesheet [ <!ENTITY nbsp " "> ]><xsl:stylesheet version="1.0" xmlns:xsl="http://www.w3.org/1999/XSL/Transform" xmlns:msxml="urn:schemas-microsoft-com:xslt" xmlns:umbraco.library="urn:umbraco.library" exclude-result-prefixes="msxml umbraco.library"> <xsl:output method="xml" omit-xml-declaration="yes"/>
<xsl:param name="currentPage"/><xsl:template match="/">
<xsl:variable name="items" select="$currentPage/ancestor-or-self::* [@isDoc and @level = 2]/* [@isDoc and string(umbracoNaviHide) != '1']"/> <!-- The fun starts here --> <xsl:if test="count($items) > 0"><ul>
<xsl:for-each select="$items"> <li> <a href="{umbraco.library:NiceUrl(@id)}"> <xsl:value-of select="@nodeName"/> </a> </li></xsl:for-each></ul> </xsl:if>
</xsl:template>
</xsl:stylesheet>
It working perfect to me but I need every time I have to select the firstchild node How can I achive that??
Pls any ideas share with me......
Thanks in adavance...
Upload image
Second level navigation menu!!
Hi All,
my code is...
<xsl:stylesheet
version="1.0"
<ul>
<li>
</a>
</li>
</xsl:for-each>
</ul>
</xsl:if>
</xsl:template>
</xsl:stylesheet>
