  • sravani 50 posts 70 karma points
    May 24, 2011 @ 13:22
    sravani
    Second level navigation menu!!
    Hi All,
    my code is...
    <!DOCTYPE xsl:stylesheet [ <!ENTITY nbsp "&#x00A0;"> ]>
    <xsl:stylesheet
      version="1.0"
    <xsl:template match="/">
      <xsl:variable name="items" select="$currentPage/ancestor-or-self::* [@isDoc and @level = 2]/* [@isDoc and string(umbracoNaviHide) != '1']"/>
    <!-- The fun starts here -->
    <xsl:if test="count($items) &gt; 0">
    <ul>
    <xsl:for-each select="$items">
      <li>
        </a>
      </li>
    </xsl:for-each>
    </ul>
        </xsl:if>
    </xsl:template>
    </xsl:stylesheet>
    It working perfect to me but I need every time I have to select the firstchild node How can I achive that??
    Pls any ideas share with me......
    Thanks in adavance...
