HI , I created a Html bullet list
in the rich text editor on a simpel textpage but the website does not show the bullet LIST
example
but it shows
Item 1Item 2Item 3Item 4
I used css in the tempaltes but it does not seem to work
Hi Max
Are you by any chance using a reset stylesheet on your website?
It's probably because it's been set to list-style: none; somewhere in your CSS.
RichText Editor Ul Li not showing
example
but it shows
Item 1
Item 2
Item 3
Item 4
Hi Max
