  • rimi 2 posts 20 karma points
    May 11, 2009 @ 10:20
    rimi
    Lucene query syntax
    Hi ,I am using lucene search engine in my applicaiton.I am facing trouble to search a particular word like "AWT-T" . I want only match data with this particular word "AWT-T" should be shown. But right now all the data matching with AWT is also showing.
    Please help me.
    May 11, 2009 @ 10:56
    Dirk De Grave
    I'd check the lucene.net documentation for that. Don't see any umbraco relevance atm, but you could proof me wrong of course.
    /Dirk
    May 11, 2009 @ 12:55
    Ismail Mayat
    Rimi,
    Download luke and try syntax documentation here
    Regards
    Ismail
  • Douglas Robar 3570 posts 4711 karma points MVP ∞ admin c-trib
    May 11, 2009 @ 14:36
    Douglas Robar
    The simple umbSearch doesn't handle dashes very well. The dash in the search term forces lucene to use a different search algorithm, which causes peculiar results sometimes. There are a couple ways to handle this but they all require some code changes to the search tool to get the lucene behavior you want. I don't think there is a simple way to resolve it without a code change; though if you put the search term in single or double quotes you might get what you're looking for.
    Try searching for:
    AWT-T
    'AWT-T'
    "AWT-T"
    Do any of those return what you want?
    cheers,
    doug.
    May 12, 2009 @ 10:08
    rimi
    No Drobar,It's not showing the right data.It's showing the AWT related data also.I want only AWT-T data.Please help me.
