  • Mikael Mørup 297 posts 326 karma points
    May 11, 2009 @ 13:37
    Mikael Mørup
    Rich text editor problem
    I have a problem with a property based on the rich texteditor.
    TinyMCE insists on wrapping every single line in
    tags. This messes up the line spacing my editors want to have in their documents. Is there anyway to work around this ?
  • dillorscroft 198 posts 192 karma points
    May 11, 2009 @ 14:17
    dillorscroft
    This is correctly validating XHTML. Is it possible for you to include CSS to negate the visual spacing between the paragraphs?
  • Douglas Robar 3570 posts 4711 karma points MVP ∞ admin c-trib
    May 11, 2009 @ 14:32
    Douglas Robar
    You can also insert a
    by holding down the SHIFT key while pressing the Enter or Return key. If you simply press the Enter or Return key you'll get full paragraph breaks.
    cheers,
    doug.
