  • Maarten Boer 61 posts 82 karma points
    May 25, 2011 @ 21:00
    Maarten Boer
    sendmail to more then one recipient ?
    Is it possible to send mail to more then one recipient ?
    Like:
    umbraco.library.SendMail(Senderemail.Text, "john@studio.com;collin@studio.com", Subject.Text, Body.Text, false);
    When i load this ascx i get an error:
    Error reading usercontrols/sendmail.ascx
    The following list shows the Public Properties from the Control. By checking the Properties and click the "Save Properties" button at the bottom, umbraco will create the corresponding Macro Elements.
    System.Web.HttpParseException (0x80004005): There can be only one 'control' directive. ---> System.Web.HttpParseException (0x80004005): There can be only one 'control' directive. ---> System.Web.HttpException (0x80004005): There can be only one 'control' directive. at System.Web.UI.TemplateParser.ProcessError(String message) at System.Web.UI.TemplateP...............
    May 25, 2011 @ 23:37
    Lee Kelleher
    Hi Maarten,
    As far as I'm aware, you are delimiting the recipients correctly (by semicolon).
    Does the form/email work when you use a single email address?
    I'm getting a sneaky feeling that there's something else going on here - only from the exception message.
    Cheers, Lee.
    May 25, 2011 @ 23:46
    Maarten Boer
    Yes, single recipient works just fine. I'll post the script tomorrow.
    Maarten
    May 26, 2011 @ 14:07
    Maarten Boer
    Hi Lee,
    As promised here is my code....
    I changed the script a little bit. When i load this usercontrol in the macro, i dont get any error now..
    But when i send this contactform, only the last recipient receives the mail... (not the actual email adresses)
    <%@ Control Language="C#" ClassName="SendmailControl" %>
    <script runat="server">
    protected void SendMail(object sender, EventArgs e)
    string CrLf = "\r\n";
    if (string.IsNullOrWhiteSpace(kname.Text) || string.IsNullOrWhiteSpace(kemail.Text) || string.IsNullOrWhiteSpace(kmessage.Text))
    ResponseLiteral.Text = @"<br><br><p><strong>Error sending the contactform !</strong></p>";
    else
    string body = "The following information has been send from your website:" + CrLf + CrLf;
    body += "name:" + kname.Text + CrLf;
    body += "company:" + kcompany.Text + CrLf;
    body += "email:" + kemail.Text + CrLf;
    body += "telephone:" + ktelephone.Text + CrLf + CrLf;
    body += kmessage.Text + CrLf + CrLf ;
    body += "Kind regards," + CrLf;
    body += kname.Text;
    try
    umbraco.library.SendMail(kemail.Text, "john@studio-pxl.com; peter@studio-pxl.com", "Contactform from the website", body, false);
    ResponseLiteral.Text = @"<br><br><p>The contactform has been sent...</p>";
    catch (Exception)
    ResponseLiteral.Text = @"<br><br><p><strong>There was a problem sending the contactform.</strong></p>";
    FormPanel.Visible = false;
    ResponsePanel.Visible = true;
    </script>
    <form runat="server">
    <asp:Panel ID="FormPanel" CssClass="div_formpanel" runat="server">
    <label class="div_contact_item" style="top:56px">name*</label>
    <br />
    <div id="div_contact_invul" style="top:52px">
    <asp:TextBox ID="kname" runat="server" CssClass="contact_data" /><br />
    <label class="div_contact_item" style="top:89px">company</label><br />
    <div id="div_contact_invul1" style="top:85px">
    <asp:TextBox ID="kcompany" runat="server" CssClass="contact_data" /><br />
    <label class="div_contact_item" style="top:121px">email*</label><br />
    <div id="div_contact_invul1" style="top:118px">
    <asp:TextBox ID="kemail" runat="server" CssClass="contact_data" />
    <br />
    <label class="div_contact_item" style="top:155px">telephone</label><br />
    <div id="div_contact_invul1" style="top:151px">
    <asp:TextBox ID="ktelephone" runat="server" CssClass="contact_data" /><br />
    <label class="div_contact_item" style="top:185px">message*</label><br />
    <div id="div_contact_invul2" style="top:184px">
    <asp:TextBox ID="kmessage" TextMode="multiline" runat="server" CssClass="contact_data1" /><br />
    <div id="div_nextpage">
    <asp:Button ID="SendButton" runat="server" Text="send" OnClick="SendMail" CssClass="but_sturen" />
    </asp:Panel>
    <asp:Panel ID="ResponsePanel" CssClass="div_antwoordpanel" runat="server" Visible="false">
    <asp:Literal ID="ResponseLiteral" runat="server" />
    </asp:Panel>
    </form>
    Any idea why not both recipients receive the mail  ???
    Also i would like the recipients to be a parameter when i insert the macro in the richtext box.
    Maarten
  • Ravi Motha 290 posts 500 karma points MVP 8x c-trib
    May 26, 2011 @ 14:17
    Ravi Motha
    Is the mail server showing you the messages for the delimited users, or is it failing before it gets to the mail send?
    May 26, 2011 @ 17:48
    Maarten Boer
    The mailserver is showing the message, but only to the last recipient...   in this case peter
    May 30, 2011 @ 23:36
    Maarten Boer
    I found the solution...
    THE recipients have to be parted with a komma. Name@world.com, Name2@world.com.
    Maarten
    May 31, 2011 @ 00:22
    Ravi Motha
    does that apply to both the to and the cc field and apologies for the late responses.
    May 31, 2011 @ 08:13
    Maarten Boer
    Yes Ravi,
    According to .NET
    Maarten
