One of my customers aksed me today why umbraco opens up in a popup window. It seems very cumbersome, some browser block it and you end up with a small working area.
I have to agree with the customer. I always access the umbraco/umbraco.aspx page directly and I seem to remember from screencasts that most people do the same.
Because it gives you more room to work... the toolbars and such are disabled in the popup window so you get maximum work area and minimum distraction.
Just the same, I also prefer to use the /umbraco/umbraco.aspx url directly and opening umbraco in a tab rather than a new window.
Since I work on so many different umbraco-based sites I've created a toolbar button to launch the umbraco ui for the site I'm currently viewing. Simply create a new item on your browser's toolbar and set the location/url to the following:
We'll remove the popup in 4.1. The main reason for the popup was legacy - we had some dialogues integrated as popups (instead of the modal trick we use now). This meant that if clients were using popup blockers it wouldn't show - instead they get the browser warning about allowing popups. The problem was that if they said "sure, allow popups" the page would refresh and they would loose existing changes. Hence the trick (more than screen real estate which just was a nice side effect).
I always just call /umbraco/umbraco.aspx directly instead of /umbraco, but others simply delete default.aspx and rename umbraco.aspx to default.aspx. It works just fine.
Why is umbraco in popup window?
Is there any sound reason for the popup?
[code]javascript:url%20=%20window.location.protocol%20+%20'//'%20+%20window.location.hostname;%20window.location%20=%20url%20+%20'/umbraco/umbraco.aspx';[/code]
Then, when you're viewing any page of an umbraco-based site... click the toolbar button and you're in the umbraco editor in no time.
cheers,
doug.
Ah that's a nice trick.
Still the whole concept of working in a popup window seem very nineties. I can't recall a single web application that promotes the use of popups.
I also think, opening umbraco popup is obsolete, if you need more room, you can use F11
Petr
When i set up a new site I go to config/urlrewriting.config and add:
[code]
redirectMode="Permanent"
redirect="Application"
rewriteUrlParameter="IncludeQueryStringForRewrite"
virtualUrl="^~/login"
destinationUrl="~/umbraco/login.aspx"
ignoreCase="true" />
[/code]
This allows me to enter sitename.com/login to get save a bit of typing.
Also good for my content editors
Niels...
