Assuming I understand what you are getting at, you could try using a template ( master page ) to solve that problem. You would simply create the template and insert the corresponding life cycle events handlers in that. Otherwise, I don't believe you can put per page code without use of a Macro.
You can alter the Master Page file to reference a code behind, or simply add a <script runat="server"> </script> section to your page and add the code there.
The ASP.NET page lifecycle is still there. Although the URLs (created by content pages) are virtual; all requests are routed through the root "~/default.aspx".
As for code-behind in the MasterPage templates - sure why not? It does require adding an extra attribute to the declaration for either "CodeBehind" or "Inherits".
thank you ... i understood the the options of code behind in the masterpage ...
i know the urls are virtual , and every pages routes through "~/default.aspx". so , can i add a code behide in this page????
and if so, this code behind (in "~/default.aspx") is common for all page.. is that correct ??
so in all options , the code behind is common for some pages (in "~/default.aspx" or in template )
You could add code behind for the "default.aspx" page ... if you do, I'll need to create a class that inherits from "umbraco.UmbracoDefault" - otherwise you'll bork your front-end completely! I'd advise against this too - reason being that when you come to do an upgrade, you don't want to overwrite any bespoke changes that you've made.
In all honesty, I don't really understand what your issue is with using a user-control/macro? Feels like you're trying to swim upstream, when it's much easier to go with the flow of the cms/framework.
hi... lifecycle question
hi ....
i got a question ... since .aspx file are not really exists .. so there is no page lyfecycle and no page.load etc..
how can i have some server code on page.load of a page ??
i dont want to use (as a macro ) a user control lifecycle ... or httpmodule is there any other option ???
hope i made myself clear ...
thanks
ok... but how can i put some server code on the template ...
it is like masterpage with no code behind...
like this ...
<%@ Master Language="C#" MasterPageFile="~/masterpages/umbMaster.master" AutoEventWireup="true" %>
<asp:Content ContentPlaceHolderID="cp_content" runat="server">
<div id="content" class="frontPage">
<umbraco:Item runat="server" field="bodyText"/>
</asp:Content>
Hi gilpt,
... or you can add code inline, like so...
<%@ Master Language="C#" MasterPageFile="~/masterpages/umbMaster.master" AutoEventWireup="true" %> <script runat="server"> protected void Page_Load(object sender, EventArgs e) { this.Label1.Text = "Howdy Partner!"; } </script> <asp:Content ContentPlaceHolderID="cp_content" runat="server"> <div id="content" class="frontPage"> <asp:Label runat="server" ID="Label1" /> <umbraco:Item runat="server" field="bodyText"/> </div> </asp:Content>Cheers, Lee.
is that correct ???
thanks a lot
Cheers, Lee.
