  • Jonas Eriksson 930 posts 1825 karma points
    May 26, 2011 @ 18:02
    Jonas Eriksson
    Protect a staging site?
    Hi!
    How do you protect a staging site from unwanted visitors, so that the browser demands a username + password before anyone can access it at all?
    Regards
    Jonas
    May 26, 2011 @ 18:16
    Jonas Eriksson
    I made some attempts to make IIS handle it, but it looks like I cannot have that at the same time as redirect based protection. So the best option might be to setup a simple login form and a single user protection within Umbraco ?
    http://mvolo.com/blogs/serverside/archive/2008/02/11/IIS-7.0-Two_2D00_Level-Authentication-with-Forms-Authentication-and-Windows-Authentication.aspx
  • Mike Chambers 636 posts 1253 karma points c-trib
    May 26, 2011 @ 18:55
    Jun 01, 2011 @ 11:08
    Jonas Eriksson
    Thanks, but I'm not sure I want that - as I like to have an environment that's as similar to the live site as possible. And if the live site is using membership I think this will be a bit messy?
    Jun 01, 2011 @ 14:35
    Jonas Eriksson
    @sitereactor & @elspiki wisely adviced me to simply restrict access by IP-address. Doing so now.
