  • SinkyPars 132 posts 175 karma points
    May 27, 2011 @ 15:48
    SinkyPars
    tinyMCE and image spacing
    Hi guys,
    I have inserted an image in to tinyMCE which has text wrapping it.
    I have tried to add a class to the image using the styles drop down to give it a margin but this does not get applied to the image.
    This in turn is wrapping the text to close to the image.
    Can anyone suggest a solution?
    S
    May 27, 2011 @ 22:40
    Kim Andersen
    Hi SInkyPars
    When you click the inserted image, and afterwards selects a style from the styles dropdown, are you then saying that the class are not applied in the editor or in the rendered content on the frontend? Or both places?
    /Kim A
