I have an image in a master tempate that shows fine when the home page displays, but does not show in any of the child tempates. All other content in the master shows in the child templates.
I used an upload for the image, and added an img tag to it -
image from master not showing in child
Any help would be appreciated.
thnx
If the property is set on the parent node you have to specify that it should get the value recursively in the template.
Like this:
Thank you so much!
Any ideas on where I could see some documentation where that type of stuff is documented?
