  • gilpt 33 posts 53 karma points
    May 29, 2011 @ 09:47
    gilpt
    hi ....
    i got i little question...
    how can i create subfolders whithin my webapp?  so i can put some content(pages ) in it ...
    thanks
  • Ove Andersen 435 posts 1541 karma points c-trib
    May 29, 2011 @ 10:17
    Ove Andersen
    Go to the admin section www.your-url/umbraco/ and log in.
    Right click the "Content" node or another node you want to create content under, and click "Create".
    You should also take a look at these free introduction videos:
    http://umbraco.com/help-and-support/video-tutorials/introduction-to-umbraco
    May 29, 2011 @ 11:15
    gilpt
    i know that i can create a subcontent by right clicking the upper node
    and i can go to  www.myurl.com/page.aspx
    and ... www.myurl.com/page/subpage.aspx
     ... but can i actually create a folder (with a folder icon )
    so the upper node is not a content ....
    hope i made myself clear
  • Jonny Irwin 91 posts 153 karma points
    May 29, 2011 @ 22:43
    Jonny Irwin
    You can create a new document type to use as a folder (giving it a folder icon if you wish) and use this to organise your other content nodes.
  • Sean Holmesby 61 posts 82 karma points
    May 30, 2011 @ 03:09
    Sean Holmesby
    I think the issue you may have with this is if you don't want your folder to be a page on your site. If it's like, a container for items, then the issue you may have is that the folder is technically a page on your site....and some XSLTs with [@isDoc] will still execute as though it were just a normal page.
    Is that the idea behind what you're trying to achieve?
    May 30, 2011 @ 08:52
    gilpt
    that is right i do not want my folder to be a page in the website ... it should be just an item's container
    May 31, 2011 @ 02:38
    Sean Holmesby
    I started by using the Creative Website Starter package with my site, and it has a folder outside of the website structure which it references for the front page slider images. Perhaps you could use the same sort of thing, where you have a folder on the same level as your home node (not as a child of it), and have your code reference that folder directly, retrieving all of it's contents.
    i.e
     - Content
    -----Home Page Node
    -------------Page 1
    -------------Page 2
    -----Folder
    -------------Item 1
    -------------Item 2
    -------------Item 3
