where is the best way to redirect from one page to another ...
usercontrol? template? httpmodule?
i want to have general redirection accotding to a cookie data ..
thanks
Put a content picker in your document type with an alias of umbracoRedirect and the page will redirect to whatever page you select in the content picker.
Are you looking at redirecting straight away, i.e on page load.... or after a specific event or click on the page?
Jonny, does your solution work straight away, or do you have code actually executing the redirect?
jonny solution works straight away
hi...
thanks
