    Jun 01, 2011 @ 09:10
    Anthony Candaele
    Umbraco backend via SSL
    Is it possible to have the Umbraco Backend accessible through a secured SSL connection while the public website is served through a normal http connection?
    Thanks for your advice,
    Anthony Candaele
    Belgium
    Jun 01, 2011 @ 09:24
    Lee Kelleher
    Hi Anthony,
    Yes it's possible.  Once you have got your SSL certificated installed and set-up for your domain.  Go into your Web.config file and set the "umbracoUseSSL" appSettings key to "true".
    <add key="umbracoUseSSL" value="true" />
    Cheers, Lee.
    Jun 01, 2011 @ 09:30
    Anthony Candaele
    Hi Lee,
    Thanks, I already saw the setting in the web.config file but I didn't know it was that simple.
    thanks for your help,
    Anthony
