Any subsiquent save after result in the error below.
[ArgumentOutOfRangeException: Length cannot be less than zero.
Parameter name: length]
I compared the initial macro html (see html above) with the "after first save" html and the difference is the "<!-- startUmbMacro -->f<!-- endUmbMacro -->" text is missing. The Save the tinymce is doing strips this text out. if I add this text to the macro html it saves fine but then gets stripped again. I cant ask the content editors to manually add this to each RTE.
This is a stock install of 4.7. I haven't customized the tinymce at all.
This is going to be one of those, "not sure why its working now". Chrome seems to be working like it does normally with the content editor. Thanks for your input thought Jan, much appreciated.
I'm having this same issue. But mine is not fixing itself.
Does anyone have any idea why it's stripping the "<!-- startUmbMacro --><!-- endUmbMacro -->" tags in tinyMCE or why the "Length cannot be less than zero.Parameter name: length" error is being thrown when trying to save the content when these tags have been stripped.
I'm trying to upgrade to version 4.7.0 but this issue has me at a stand still.
TinyMCE is stripping the <!-- startUmbMacro -->f<!-- endUmbMacro --> from macro markup
First off I'm running 4.7 and framework 4.0.
The issue is when I insert a macro the html looks like this
<div class="sections-header grid_9 alpha omega">
<h3 class="grid_8 alpha"><span>AQS</span> Section Navigation</h3></div>
<p>test</p>
<div umb_ulclass="sections grid_6 prefix_1 alpha omega" umb_propertyname="" umb_contentitemid="1053" umb_macroalias="BoxLinks" ismacro="true" onresizestart="return false;" umbversionid="9ce3f96a-ad64-418f-a6d4-2d5e3641dd00" umbpageid="1132" title="This is rendered content from macro" class="umbMacroHolder"><!-- startUmbMacro -->'<!-- endUmbMacro --></div>
I can save this html without an issue
Anyone have any idea's?
thanks,
-adam
Hi Adam
What browser do you experience this on and is the error happening in other browsers as well?
Thanks for any help you can give.
-Gregg
