  • Fredrik Esseen 610 posts 906 karma points
    May 28, 2009 @ 10:24
    Fredrik Esseen
    Get thumbnails from tinyMce
    I have several customers who wants to upload a full size image and then use different sizes of that image.
    Since I dont want the user to use the full size and change the size I want to use the thumbnails that gets created whn the image is uploaded.
    Are there any way I can achieve this?
  • Lesley 284 posts 143 karma points
    Jun 01, 2009 @ 17:55
    Lesley
    Hi froad,
    Have you looked at Doug's ImageGen?
    Lesley
    Jun 02, 2009 @ 08:32
    Fredrik Esseen
    Do you mean that if I use the Imagegen I can somehow make the upload datatype to use that and I will be able to retrieve the thumbnails from the editor?
  • Petr Snobelt 923 posts 1535 karma points
    Jun 02, 2009 @ 08:57
    Petr Snobelt
    I think it can be done using simple macro but I know it's far from ideal.
    But when user resize image in editor new image with resized width and height is created automatically. Maybe you don't need use thumbnails.
    ImageGen is great, but it has no support in tinyMce, so is relatively hard for editors to use it.
    Petr
    Jun 02, 2009 @ 09:02
    Fredrik Esseen
    My main problem is that the user should be able to upload a full size image and then it should be automatically saved in a number of different sizes.
    But do you mean that its automatically saved a smaller image when a user resizes it in editor? In that case that solves it! Can you or anyone else confirm that?
    Jun 02, 2009 @ 09:58
    Fredrik Esseen
    Another problem with that: When the user have resized the image and the image is saved as for example glas1_250x166.jpg and is located in the same folder on the server as the original, the user cant retrieve that image in any way but has to create a new image.
    Why cant all images be retreieved in image archive??
    Or is it just me who want to have that possibility?
    Jun 02, 2009 @ 16:08
    Petr Snobelt
    If you have some prefered width/height properties, umbraco can create this image automatically, when you add image into media section. But there is no support to retrive it other then manually update image url.
    Petr
    Jun 02, 2009 @ 16:45
    Fredrik Esseen
    And that possibility to get the image from the editor is what Im looking for. Getting the image from a macro or writing it manually is not very user friendly. The customer wants to be able to pick an image and display it in the editor.
