I've got a need to show some additional information "at a glance" that I'd like to do by showing different icons in the content tree (think of twibbons on twitter).
I'm assuming the backend does this for unpublished items, is there anyway to do your own customer icon mods on the fly based on the actual data in a content item? An example would be to show if a product in the back end was flagged as "not on sale".
Like Lee says, the code from Matt's mediaicons should show you how to do it from a code point of view.
The only issue that I can see would be that to check what's in the page, you'd have to load the Document to check, which could be quite slow, if the document has a LOT of properties, or the content tree has 100's+ of nodes in it. That said, I've done similar for fairly large sites, and the performance hit hasn't actually been all that bad.
Based on the code from Matt's mediaicons, i can get icons based on nodeName.
Offcourse it requires some icons and an idea of what the nodenames will be. My situation was sports, so its easy to predict the names. Could be extended with a call to Bing translatyion, if your site have multiple languages.
Here is the new version of Matt's Appbase.cs:
In the line containing this :nodeItem.ContentType.Alias == "SportAndActivityPage" || nodeItem.ContentType.Alias == "CategoryPage" , you can specify which bode types to filter on.
using System; using System.IO; using umbraco.BusinessLogic; using umbraco.cms.businesslogic.media; using umbraco.cms.presentation.Trees; using umbraco.IO; using umbraco; using umbraco.cms.businesslogic.web; using umbraco.NodeFactory; using System.Net; using umbraco.cms.businesslogic.language;
namespace TheOutfield.UmbExt.MediaIcons.Logic { public class AppBase : ApplicationBase { public AppBase() { BaseTree.BeforeNodeRender += BaseTree_BeforeNodeRender; }
protected void BaseTree_BeforeNodeRender(ref XmlTree sender, ref XmlTreeNode node, EventArgs e) { var ext = ""; var nodeFileProp = "";
if (node.NodeType == "media") {
var mediaItem = new Media(Convert.ToInt32(node.NodeID)); if (mediaItem.ContentType.Alias != "Folder") { var mediaFileProp = mediaItem.getProperty("umbracoFile"); if (mediaFileProp != null) { var mediaFile = mediaFileProp.Value.ToString(); if (!string.IsNullOrEmpty(mediaFile) && mediaFile.LastIndexOf(".") < mediaFile.Length) { ext = mediaFile.Substring(mediaFile.ToLower().LastIndexOf(".") + 1); } } } if (!string.IsNullOrEmpty(ext)) { var iconUrl = string.Format("/umbraco/images/umbraco/{0}.gif", ext); if (File.Exists(IOHelper.MapPath(iconUrl))) { node.Icon = ext + ".gif";
} } } if (node.NodeType == "content") { Document nodeItem = new Document(Convert.ToInt32(node.NodeID)); if (nodeItem.ContentType.Alias != "Folder") {
Alternative option is a package we recently developed called Page State Icons - which can add a small overlay icon to the node's icon. Uses XPath against the node.
Currently only does overlay icons, but could be modified to replace the entire image/icon.
Hi, on a related note thought it might be worth mentioning the Auto Icons package as a quick way of setting the default icons for document / media types based on their aliases (it's a file naming convention - similar to the above, over back office configuration).
Custom icon based on content in the page?
Ideas, solutions or thoughts please :)
Hi Peter,
Sounds similar to the Icon Picker package... with a twist of intelligence!
... or grab the source from Matt's Media Icons package and adapt accordingly.
Cheers, Lee.
Looks good Peter.
Cheers, Lee.
