  • Matt Taylor 873 posts 2086 karma points
    Jun 03, 2011 @ 18:33
    Matt Taylor
    Please help clear up my SSL & Hostname confusion
    I'm familar with creating different site branches in Umbraco and assigning a hostname to each.
    • www.mysite.com
    • www.mysite.dk
    When I'm testing this I'll usually create one site in IIS 7 and add the hostnames under 'Bindings'.
    Now I have a requirement to secure these sites with SSL which I am looking at for the first time.
    Is it possible to secure both these sites with the same certificate or will I have to create an IIS site for each one and assign a seperate certificate for each one?
    Matt
  • Marco Fernandes 15 posts 51 karma points
    Jun 04, 2011 @ 16:35
    Marco Fernandes
    I think it is possible to have a multiple domain certificate, but that will cost you.
    I suggest you SSL one of the domains a make the other redirect to the first one, or SSL both the domains...
    Best Regards,
    Marco
    Jun 06, 2011 @ 11:30
    Matt Taylor
    Hi Marco,
    Yes multi-domain certificates do seem to cost.
    I don't think I can redirect one domain to the other because that would change the domain name and then Umbraco would not be detecting the correct hostname and display the correct site.
