sHello all, here's a snippet of xslt that seems to disobey the laws of physics...
1 <xsl:value-of select="@createDate"/><br/>2 <xsl:value-of select="umbraco.library:LongDate('2011-06-03T10:30:46')"/><br/>3 <xsl:value-of select="umbraco.library:LongDate('@createDate')"/><br/>
Line 1 works ... the create date is rendered from the @createDate property.
Line 2 works ... the static text date is rendered and formatted.
Line 3 fails ... nothing is rendered. Huh?
All advice appreciated. Cheers,
-R
should be
<xsl:value-of select="umbraco.library:LongDate(@createDate)"/><br/>
Thanks Eran! We copied the source from an online video but apparently missed that. Appreciate your help,
Upload image
Perplexed by umbraco.library calls
-R
should be
-R
