  • mewfin 40 posts 20 karma points
    May 28, 2009 @ 11:04
    mewfin
    Emergency fix [SOLVED]
    Was just about to put a site live when umbraco suddenly started acting weird.
    I cant update any nodes. the changes seems to go thrue in the database but when i check at the site the nodes are the same as before. even simple stuff like changing a text on a normal page cant be done.
    Anyone have any ideas?
    May 28, 2009 @ 11:06
    mewfin
    humm if i connect with a copy of the umbraco install from on my testserver to the same database as the real site everything is working. So there has to be something cached or coud there be any other errors on the other server doing this?
  • Richard Soeteman 4052 posts 12925 karma points MVP 2x
    May 28, 2009 @ 11:19
    Richard Soeteman
    Did you check the folder security on the site?Checkout this document for the settings? Umbraco is writing the published content to the Data/Umbraco.Config file. So if that file cannot be updated you content isn't visible.
    Hope it helps you,
    Richard
    May 28, 2009 @ 11:42
    mewfin
    awesome! that did it. my colleague had changed changed the folder the otherday so the permissions had been changed. huge thanks.
