It seems to me that there should be enough id's and classes available as styling hooks in the rendered HTML so it should really just be a matter of overruling the default styling of the form, right?
But I didn't found out to implement all the styling rules yet. But I guess like you said, it's a matter of overruling the default definition style of the contour form.
If you don't have direct access to the contour stylesheet you can overwrite the declarations by adding your form styles AFTER the contour stylesheet has been linked. Then you can overrule them all by using the same selector and changing the properties you need to change.
If you for some reason run into an issue regarding specificity you can alwas use !important as a last resort. But prefferably it's better to use html in front of the selector like...html p.response{property:value}...
Rather than over-riding the default CSS style, just disable it by going into your forms Settings tab in the back end, and checking the "Disable Default Stylesheet" option.
I originally tried to re-style a Contour form without disabling the stylesheet, but it causes a few problems and isn't as easy as it should be. Disabling the default stylesheet makes it super easy to style :)
styling Contour forms
I have made a contact form with Contour on my website: http://www.webmove.be/startpagina/contact
Does anyone know how to style a Contour form?
Thanks for your advice,
Anthony Candaele
Belgium
Hi Anthony
Are you thinking about something specifically?
Hi Jan,
Yes I guess. I have these style definition rules for my contact form, and I would like them to be implemented to the Contour contactform:
#contactform { margin:0; padding:5px 10px;}
#contactform * { color:#5f5f5f;}
#contactform ol { margin:0; padding:0; list-style:none;}
#contactform li { margin:0; padding:0; background:none; border:none; display:block;}
#contactform li.buttons { margin:5px 0 5px 0;}
#contactform label { margin:0; width:110px; display:block; padding:3px 0; font:bold 12px Arial, Helvetica, sans-serif; color:#5f5f5f; text-transform:capitalize;}
#contactform label span { display:block; font:normal 10px Arial, Helvetica, sans-serif;}
#contactform input.text { width:540px; border:1px solid #d0d0d0; margin:3px 0; padding:5px 2px; height:16px; background:#ffffff;}
#contactform textarea { width:540px; border:1px solid #d0d0d0; margin:3px 0; padding:2px; background:#ffffff;}
#contactform li.buttons input { padding:3px 0; margin:0; border:0; color:#FFF;}
p.response { text-align:center; color:red; font:bold 11px Arial, Helvetica, sans-serif; line-height:1.8em; width:auto;}
I already found out that if I omit the css identifier (#contactforom), some of the styles get implemented, like for example:
greetings,
Anthony
Hi Anthony
Hope this makes sense.
