    Jun 03, 2009 @ 11:05
    Ismail Mayat
    umbracoUrlAlias and url rewrite
    Does umbracoUrlAlias work when you have urlrewrites setup?
    I have 2 sites one that has no url rewrites and I am using umbracoUrlAlias setup as per Dirk's excellent post all works fine.
    I have a second site that has some url rewrite rules, when i try to use umbracoUrlAlias i just get page not found. The umbracoUrlAlias url that i am using does not match any of the reg ex's in url re write rules.
    Regards
    Ismail
  • Jonathan Cohen 40 posts 115 karma points
    Feb 22, 2011 @ 22:32
    Jonathan Cohen
    An old post, and I am not sure if I have the same problem.
    I have a page: "/apage/subpage"
    This page as an umbracoUrlAlias: "thepage"
    And i have a urlrewrite "anotherpage/sometext/1234"   that points to "thepage?id=1234", but it does not seem to work.
    The umbracoUrlAlias path and the original path i can browse, the rewrite gives a 404.
    (Umbraco 4.61)
    Any ideas?
    Thanx
    Jonathan
