  • seanrock 262 posts 483 karma points
    Jun 03, 2009 @ 13:43
    seanrock
    Help
    I'm new to umbraco and having some problems getting my head around it. I'm hoping someone can shed some light.
    i've created a doc type (p.s. the videos seem outdated and confusing), and a template. the template references /umbraco/masterpages/default.master and i cannot seem to change this (do i need to?). Also i've notice a masterpage is created for each template. So where do i put my html head tags and doc types declarations etc that i would normally put in a masterpage? Do i put it in the /umbraco/masterpages/default.master or do i put it in the masterpage that relates to my template?
    Sean
    Jun 03, 2009 @ 13:53
    Dirk De Grave
    A must read blog on setting up templates/master pages and the like can be found at: http://creativewebspecialist.co.uk/2008/09/23/screencast-on-umbraco-v4-masterpages.aspx
    And a nice compiled list of good references can be found at: http://www.nibble.be/?p=56
    Hope this helps.
    Cheer
    Jun 03, 2009 @ 14:49
    seanrock
    Thank you Dirk.
    Regards
    Sean
