The above is a simple representation of a configuration that i have set up for a site and I am getting strange behaviour that I do not understand and hope to get some more understanding here.
Web 1 and Web 2 are virtual web servers running windows server 2008 R2 Enterprise edition with Service pack 1 installed that both point to a single file share on a separate machine. There is also a separate database server.
The situation - I can navigate to the admin section of Web 1 and make some content changes, publish them and they are immediately available on Web1. The umbraco.config file is correctly updated as expected.
However, Web 2 does not reflect these changes immediately. In IIS7 on both servers Response caching has been turned off at the server level and the site level. I have also tried setting "Maximum cached response...." to 0. Once I do an IIS reset, the content in available on Web 2 but for obvious reasons this is not a solution.
So my question is, where could this caching be heppening? Are there some other settings in umbracoSettings.config or elsewhere that I should be looking at to alleviate this problem?
Caching umbraco.config and umbracoSettings.config
Hi All
Bradley
