  • Patrick 2 posts 22 karma points
    Jun 09, 2011 @ 00:25
    Patrick
    Multiple Macros Failing
    I can currently only get one macro at a time to work on a page.  I thought initially it had something to do with the new macro (for a social media widget) that I created, but now all my pages that had multiple macros only display the first one.  When I edit the page and put in a second macro, then save, when it reloads the second macro is gone.
    What's going on?
    Jun 09, 2011 @ 01:10
    Patrick
    One sub issue is that one of my xslt files is failing.  I haven't edited this macro, so not sure why it's failing now on save with a overflow error.  Here's the detail:
    version="1.0" encoding="UTF-8"?>
    xsl:stylesheet [
    <xsl:stylesheet
      version="1.0"
      <xsl:output method="xml" omit-xml-declaration="yes"/>
      <xsl:param name="currentPage"/>
      <xsl:template match="/">
        <xsl:variable name="fixedHref" >
            <xsl:call-template name="fixRssHref">
              <xsl:with-param name="niceUrl">
                <xsl:value-of select="umbraco.library:NiceUrl($currentPage/ancestor-or-self::root//umbBlog/@id)" />
              xsl:with-param>
          xsl:call-template>
        xsl:variable>
        <link href="{concat($fixedHref, '/rss.aspx')}" rel="alternate" type="application/rss+xml" title="RSS Feed" />
        <xsl:if test="string-length(umbraco.library:Request('filterby')) > 0">
          <link href="{concat($fixedHref, concat('/rss/tags/',umbraco.library:Request('filterby'),'.aspx'))}" rel="alternate" type="application/rss+xml" title="RSS Feed for tag {umbraco.library:Request('filterby')}" />
        xsl:if>
        <link href="{concat($fixedHref, '/commentrss.aspx')}" rel="alternate" type="application/rss+xml" title="Comments RSS Feed" />
        <xsl:if test="string($currentPage/umbBlogPost/closeComments) != '1'">
          <xsl:variable name="fixedPostHref" >
                <xsl:value-of select="umbraco.library:NiceUrl($currentPage/@id)" />
              xsl:with-param>
            xsl:call-template>
          xsl:variable>
          <link href="{concat($fixedPostHref, '/commentrss.aspx')}" rel="alternate" type="application/rss+xml" title="Comments RSS Feed for {$currentPage/@nodeName}" />
        xsl:if>
      xsl:template>
      <xsl:template name="fixRssHref">
        <xsl:param name="niceUrl" />
        <xsl:variable name="indexOfAspx" select="umbraco.library:LastIndexOf($niceUrl, '.aspx')" />
          <xsl:choose>
            <xsl:when test="$indexOfAspx != -1">
              <xsl:value-of select="umbraco.library:Replace($niceUrl, '.aspx', '')" />
            xsl:when>
            <xsl:otherwise>
              <xsl:value-of select="$niceUrl" />
            xsl:otherwise>
          xsl:choose>
        xsl:variable>
        <xsl:value-of select="$fixedHref" />
      xsl:template>
    xsl:stylesheet>
    Error occured
    System.OverflowException: Value was either too large or too small for an Int32.
    at System.Convert.ToInt32(Double value)
    at System.Double.System.IConvertible.ToInt32(IFormatProvider provider)
    at System.Convert.ChangeType(Object value, Type conversionType, IFormatProvider provider)
    at System.Xml.Xsl.Runtime.XmlQueryRuntime.ChangeTypeXsltArgument(XmlQueryType xmlType, Object value, Type destinationType)
    at System.Xml.Xsl.Runtime.XmlQueryContext.InvokeXsltLateBoundFunction(String name, String namespaceUri, IList`1[] args)
    at (XmlQueryRuntime {urn:schemas-microsoft-com:xslt-debug}runtime)
    at Root(XmlQueryRuntime {urn:schemas-microsoft-com:xslt-debug}runtime)
    at Execute(XmlQueryRuntime {urn:schemas-microsoft-com:xslt-debug}runtime)
    at System.Xml.Xsl.XmlILCommand.Execute(Object defaultDocument, XmlResolver dataSources, XsltArgumentList argumentList, XmlSequenceWriter results)
    at System.Xml.Xsl.XmlILCommand.Execute(Object defaultDocument, XmlResolver dataSources, XsltArgumentList argumentList, XmlWriter writer)
    at System.Xml.Xsl.XslCompiledTransform.Transform(IXPathNavigable input, XsltArgumentList arguments, XmlWriter results, XmlResolver documentResolver)
    at System.Xml.Xsl.XslCompiledTransform.Transform(IXPathNavigable input, XsltArgumentList arguments, TextWriter results)
    at umbraco.presentation.webservices.codeEditorSave.SaveXslt(String fileName, String oldName, String fileContents, Boolean ignoreDebugging
